Hi guys,
We are having a problem with the sidebar in our website. It is not showing up in the rigth place but is overflowing to the bottom part. When I look at the css there is some extra width that is controlling this, seems to be related with a column/row in Visual Composer but I don’t see how to solve it.
Can you help me with that? The website is this one:
http://tempoearte-h1st.net/IndianRoseLife/
I’ve checked your site and noticed that you’re using an older them’s version. Try to update the theme at V 3.0 which is available in themeforet: https://forum.tagdiv.com/newsmag-how-to-update-the-theme/ clear all caches, deactivate the child theme then test again.
Let me know how it goes.
So
By taking out the child-theme it works…However now my question is:
I can’t use a child theme with Newsmag? Even with no css modification the child-theme itself give problems, I’m pointing the child-theme to ./stule.css should I do it to other file?
The theme is tested and works fine even with its child theme active. Make sure that you installed the child theme included in theme’s path: http://screencast.com/t/q5K1vrmBA clear all caches then test again.
