sidebar problems
If I put the bar (Sidebar) on the right side, right in the sight of mobile devices, the sidebar is loaded between the title and content, as Fix it
Not having this issue.
Perhaps link to example or better explanation of your problem?
Digi please provide a link to your site also I can inspect this as in the case you’ve mentioned the sidebar should fall under posts’s content on mobile screes.
Good show fails if the right-hand side bar will be displayed on mobile well, so a ccs code, what I did was not the sidebar appear in mobile phones.
@media
(max-width: 767px) {
.single .td-main-sidebar {
display: none !important;
Not really sure what you mean but if hiding it dose work for it it’s ok. Provide a link and more details if you still need help.
