For some reason the sidebar widget is left-aligning in mobile, even though the CSS of the widget is set to center within tagdiv composer. You can see an example here (scroll down nearer the end for the advertisement): https://rareparenting.com/books-for-children-about-disability/. Usually in these situations it seems I have to add CSS to the Live CSS within the Editor.. could you let me know what to add in order to ensure the widgets center align? Or is it something else?
Hi Bettina,
Adding a margin to the widget didn’t change anything.
Hello Megan!
If you will center the text align: https://prnt.sc/QbJP64dGCKWf then the ad will be centered as well.
Thanks, Bettina, how did you do that? There doesn’t seem to be a text align option in tagdiv, just the H.align (which is already centered).
Hi Bettina,
That code actually centered all things on the page (headers, titles, bylines, social, etc).
Hello Megan!
– admin url and credentials
We will take a look and try to help you asap.
