I know I probably should take this over to the plugin developers page.
Having a problem locating that just now.
Anyone have a problem using the Silence Is Golden SIG Guard Plugin when clicking the index.php to show empty
It leads to a infinite Loop and I can’t get to plugins directory.
I deleted the Plugin via FTP
I just thought I’d ask here if anyone’s run intot his problem and how to do a quick fix.
Update on this situation:
Developer of SIG plugin responded:
“I suppose that your active theme index.php was rewritten accidentally. Check that. If it was really happend, restore original index.php file from a backup copy.”
But that didn’t work.
So I guess Ill have to reinstall and start over.
Moral: If using SIG Plugin, make sure to ReBuild and caution when using “index.php Redirect” option.
