SIMION: problem with the alignment of rankings
Dear Simion,
On https://www.coupdepoker.com I removed date and author and used some CSS to have the rankings (stars) below the title on the HP. It worked well on “CULTURE POKER” for “Sélection de livres techniques sur le poker”.
The CSS I used is:
.td_module_6 .item-details {
display: flex;
align-items: center;
flex-flow: wrap;
I installed a new category on the HP, called “POKER EN LIGNE” and, I don’t understand why the stars of the 1st line in module 6 (POKERSTARS) are not below like the other ones.
Here’s a screenshop: https://ibb.co/cS4Ti9
Could you kindly help?
Without that code the result would be like this
– https://www.screencast.com/t/YmKBO5eTe8rJ
So the reviews would be in the position you want by default. Why exactly is that code needed?
Hi Simion,
I used that code so the titles would be centered but you’re probably right, I can live without it.
Regards
