"Single more from author" posts issue
I found a very unexpected issue: I created a “Single more from author” element and I copy-pasted it in another row. But the posts of the two elements don’t match, as you can see from the pictures.
How can I fix this?
https://imgur.com/03ZOn4w
https://imgur.com/VvmTzz5
Hello !
It changes because it is not fixed. The element is called, ” Single MORE from author “. You are duplicating the element but the content will change.
