Single Page/Post Problem
Please help me, I tried to redesign my single page before then I found out that the Cloud templates are nonsense, I can’t do a better design like when I was using Elementor/Wpbakery. now my single page is conflicting with the old design. how do I fix this?
Check these 2 links and you will understand what I mean: https://www.cloudorian.com/sony-shuts-down-concrete-genie-studio-pixelopus/
https://www.cloudorian.com/virtual-proximity-sensing-vps/
Your website has malware, please check this topic https://forum.tagdiv.com/topic/update-required-newspaper-12-1-1-brings-extra-security/ and try to clear your files.
Also, the template issue is caused by the WP BAKERY plugin.
I have removed the WPBakery and it seems everything is OK.
You mentioned something about a malware, please is there anyway I can detect a malware in my site like plugins, tools etc.
I have checked most files but it seems like there is nothing there, I have also changed passwords. Help me. Thank you
When I visit the website, there was a redirect. You can use wp scan or tool like this.
A redirect, please where is it redirecting to?
This is what your plugin keep on displaying.. I have deleted and reinstalled many times but doesn’t work.
Check tagdiv
Please deactivate, delete, and reinstall tagDiv Composer from Newspaper plugins => https://www.screencast.com/t/OrzLvR2j and clear all cache.
There was no issue, there were issues with the plugin version only https://forum.tagdiv.com/topic/jetpack-alert-about-td-composer-vulnerability/
I have done that, and it worked.. Thank you so much.
Please don’t be angry, is there any workaround for this “WP <= 6.2 – Unauthenticated Blind SSRF via DNS Rebinding”
