my single post article is loading automatically, how can i prevent to load next article.
That is the infinite load for posts. It can be disabled if you do not want it. Please edit the post template with the composer, for example https://prnt.sc/ucx5b4 and disable it from here https://prnt.sc/ucx5ln
