Hi team,
Where can I modify these original files for the ones created by me in Cloud Library?
I can’t find the option on the control panel.
– single.php
– taxonomy.php
– Sidebar.php
I can’t wait to test the speed of the new update, but I still have to remove a lot of dependencies I can’t find.
So in order to achieve a better speed, you’ll need to remove the dependencies ( standard elements from the theme ) -> http://prntscr.com/ptlqqp If your website uses any of the templates/blocks present there, you must replace it with its equivalent from the tagDiv Cloud Library, in this way you’ll not longer need to have activate the standard pack plugin.
We recommend to make this local host or on sub-domain in this way you’ll make sure that this will not interfere with your online website.
Hi Calin,
I’m a little clumsy about this. But I’ll try until I get it.
I have created a new header with template cloud, I have activated it from the newspaper control panel. But when under the page, the header disappears and appears the original “unmodified”.
How can I avoid this?
And the post/publications, appear with this error in group:
This is the website: https://cutt.ly/oeTZNd9 ((now the standard plugin is activated and the header replaced by the theme, to avoid problems with visits)
If you have set a header from tagDiv Cloud Library, you need to edit the sticky menu too, edit that header template using header manager -> https://www.screencast.com/t/FkAe80JsuCo check the sticky menu, scroll until you see the sticky menu and click the menu, logo … -> https://www.screencast.com/t/o6Z8zoJoWbFY
For the second problem is appealing that you still have set same classic style that now are set in standard pack you need to make sure that you set on all posts a single post template from cloud.
Let me know the results!
All the posts need to be set on post template “From panel” -> http://prntscr.com/pu2uil after that in theme panel you need to set the single post template -> http://prntscr.com/pu2uxm
Hope this will help you!
The sidebar can be made using tag Div Composer, edit the page or template, click on the row and choose a layout -> http://prntscr.com/pw8wwp after that set the elements that you want to show in that column, if you want you can use widgets too, just set the widget sidebar -> http://prntscr.com/pw8xj8
