I’m experiencing an issue with the comments section on single posts using TagDiv Builder:
The problem: Neither existing comments nor the comment form are visible.
1.Comments are enabled in WordPress settings
2.All plugins are deactivated except the theme
3.Child theme is deactivated for testing
4.Using latest version of TagDiv Builder
5.Comments section added via TagDiv Builder
6.Inspecting the page shows an empty #comments div
Page inspection code:
<div class="comments" id="comments"></div>
Could you please assist in resolving this issue?
Best regards
To enable comments in WordPress for All Posts:
Go to Settings > Discussion in your WordPress admin panel, check “Allow people to submit comments on new posts” and save changes, as you did.
For Individual Posts:
Edit the post.
In the Discussion panel, check “Allow comments” (Enable the Discussion panel from Screen Options if not visible).
Update the post and check if the comments section is showing.
