Single post reading time works only with english text
I want to use the Single Post Reading Time element, but when the text in article is not in English, but in Greek, it always shows ‘Less than 1 min. read’.
How can I fix this? It’s likely a problem with UTF-8 coding?
  • This topic was modified 3 years by saggel.
Do you use a plugin for language?
When an article has the time reading < 1 is displayed this text https://i.imgur.com/BL8l4Sw.png you can change it.
Anamaria hello, the problem isn’t on translation, but in how the algorithm calculates the words.
Examples:
Post in english: https://bit.ly/45oHhUy (551 words)
Post in greek: https://bit.ly/3oq3ilt (575 words)
  • This reply was modified 3 years by saggel.
Do you use a plugin for translation?
I have taken your content and for me look that are two minutes -> https://i.imgur.com/NvjONCg.png Please check if you don’t have a plugin conflict.
No we don’t use plugin for translation. My site is it greek language and Single post reading time works only with english content. This is the problem.
With only this plugins active https://prnt.sc/FX7yE1ZqH9Co the single post reading time doesn’t works in greek content.
Hello @saggel !
A workaround there could be to edit this template with the TagDiv Composer: https://www.autoblog.gr/2023demo/kinezoi/ and write in Greek words.
Hello @Bettina! How to do that? I can’t edit post content with TagDiv Composer.
I insist that this is a problem with UTF-8 coding.
Do you want me to send you login credentials so you can take a look?
Hello @saggel !
Yes. Please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
Done!
Hello @bettina!
I’d like to ask you for your help.
I have the same problem in Japanese.
Please send an email, add this topic’s link, and we will help you.
