Single post template and custom post types
I have installed the cov-19 theme and it works nicely with the single post template which can be edited in the TD composer.
But when I add a custom post type, the posts are narrower than the rest of the theme and and I cannot expand the width because the template used for custom post types cannot be edited in the composer.
Is there any solution for this so the custom post types can have the same width as the rest of the theme?
Hello !
Unfortunately at the moment custom post types and Cloud library template are not working properly. Our developers are working on having this fixed in the future updates.
