i have created a single post template from cloud library. its working fine but now auto ads are not showing between anywhere in articles.
Yes, I put the code in Theme Panel -> Analytics/JS Code. But its not working with template that i have created now. earlier also this code was working with only one default single post template style 3 and not the rest.
Hi Rahul chauhan,
Normally there should bot be a problem if is a standard template or a cloud template, the auto ads should be set in one place (between the head tags). What I can suggest is to also place the code in the website header in ads place (if is a standard template need to be set in the theme panel, but for a cloud need to be set using tagDiv Composer).
Also, if you want we can investigate the situation, for this we’ll need temporary wp-admin access. This can be provide via email at contact@tagdiv.com
