Hello @wizromeo!
In order to avoid misunderstandings, please provide more information(screenshots/video) about what exactly is the issue there, what exactly you need to achieve and your website link.
I installed the Single Post Template – Magazine PRO.
When I modify a post using TagDiv Composer, it views accurately.
https://app.screencast.com/HQvJXS88gIhd7
When I save and view the post, it does not view the same as it did in TagDiv Composer.
https://app.screencast.com/6FPRwQyVm5Xej
The correct single-post template is selected in the Theme panel.
https://app.screencast.com/nk1sMAu5KS1MO
I do not think the correct template is downloading.
This reply was modified 2 years by
wizromeo.
Hello @wizromeo!
Please use only one builder: the tagdiv Composer and uninstall the WPBakery.
Clear all the cache and check the results.
If the problem is still there, then contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
– cpanel url and credentials
We will take a look and try to help you asap.
Hello @wizromeo!
We have some settings for the rows and different stretch sizes: https://www.screencast.com/t/bsbB5P97A -> https://prnt.sc/icoqdTR9_DMS4
Pluging – JNews – Essential Advertisement, Shortcode & Advertisement, Shortcode & Widget for JNews
Version 11.0.7
I’m using your MAGAZINE PRO theme. When I enable the JNews – Essential plugins, the user profile page gives an error.
There has been a critical error on this website. Please check your site admin email inbox for instructions.
Learn more about troubleshooting WordPress.
I answered to you in this topic -> https://forum.tagdiv.com/topic/jnews-essential-plugin-version-11-0-7/#post-497432
If you want to make the layout full width, then to change the website width, you need to make sure that you don’t have set a background color/image in the Theme Panel because this makes your website boxed. Make sure this option is disabled => https://www.screencast.com/t/ejiNPCBF
To set a page to full width, you’ll need to edit it with tagDiv Composer like this -> https://i.imgur.com/i5IUJ9E.jpg add or select a row and stretch it after your needs -> https://i.imgur.com/WKYebPX.jpg -> https://i.imgur.com/TO1BZ3M.png -> https://i.imgur.com/Yq8UCv3.jpg
