Hi… I currently used Newspaper 9 dan Tagdiv Cloud library,
1). I use single post template 14 for my post view. But, some post with Smart list not work (it’s look like usual article) and More Article Box disapper after changing my template.
2). I also use Review Template 3, but lost my rich snippet on Google page. Before I use article template, my review rich snippet displayed no Google search, but not today after changing to Review template 3.
It’s looks like post template from Tagdiv Cloud not work well with usual settings on theme panel.
Hello irfan.id,
1)It seems to be a mini bug regarding More Article Box elements for Post Templates. We have added to our list of improvements and we hope to fix it as soon as possible. I have checked the Smart List for Single Post Template 14 and it seems to work as expected, as you can see here -> https://www.screencast.com/t/h8AAjDZwT Where is the problem?
2)I have checked the Review functionality and it seems to works as expected. You should provide your website URL and some useful screens with the error for more investigations.
Oh.. I forget to add single smartlist block, problem solved.
But, after adding single smartlist block, the paragraph become one (it should be 3 paragraph actually), I use review template 3.
before use review template 3: https://prnt.sc/ki2vob
after use review template 3: https://prnt.sc/ki2vsc
here is the link https://irfan.id/whats-wrong-with-secretary-kim/
this is my current review template 3 https://prnt.sc/ki2xm1, only use single post smartlist.
Hello spare,
You can select the Smart List Elements by adding the shortcodes on the page (single) when you are using the Single Post from Cloud Library like this -> https://www.screencast.com/t/JmZ3llI0P
hi there,
yes this is what i did but your demo content remains inside
https://prnt.sc/kihvea
as you see i assigned my smart list to the template 5 but there is no change in it
https://prnt.sc/kihx4z
could you please tell me what excactly has to be done in order to show my own content? if its only assigning the smart list to the template and its not working then i assume its a bug?
Hello SPAREGmbH,
First of all, you should simply create your own post content using the Smart List configuration (Title/Image/Description) and then, apply it the Smart List Template. Not working? If you need more assistance in this case, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can take a closer look at it and also, so I can make a test in this case.
Oke, thanks. I will try later.
One more question,
It’s look like single post template put newest comment on the top. I want to change it back. Let the oldest comment on the top and newest at the bottom. How to do that? I dont see any option to change comment format element.
Thanks,
Hello irfan.id,
Unfortunately, the theme does not have any such an option that allows you to change this behavior, sorry! You should change it yourself through the code if you want to achieve something like this but please notice that we cannot do this because we cannot provide custom work at the moment, sorry! if you aren’t aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you. Usually, we recommend the developers from studio.envato.com.
