Site does not display content in browsers other than Firefox
Only just noticed this but my site apparently doesn’t display any content in Safari or Chrome. Plays nicely with Firefox but the other two just show the menu and header.
Running 3.9 with latest update to theme.
dev site is at
Have tried this on iOS too and again only displays header and nav icon.
Be good to know what’s causing this.
Can you give us your site URL to see the issue?
Sorry… The site address is demo.atelierhosting.com
I see that you have some JavaScript error in console, can you disable all plugins or one by one and see if works? Could be from a plugin conflict.
Hi Marius,
I’ve just done this. The plugin that’s causing the issue is your own…the Speed Booster plugin. Switching it off breaks the site on all browsers and the style sheet doesn’t load.
Will leave it off so you can troubleshoot.
Would you like admin access?
Hi Marius,
Another weird thing going on. I just got this message after I tried to delete a theme:
Warning: include(/home/atelier/public_html/demo/wp-content/themes/Newspaper/includes/td_wordpres_booster.php): failed to open stream: No such file or directory in /home/atelier/public_html/demo/wp-content/themes/DEMO Finland/functions.php on line 9
Warning: include(): Failed opening ‘/home/atelier/public_html/demo/wp-content/themes/Newspaper/includes/td_wordpres_booster.php’ for inclusion (include_path=’.:/usr/lib/php:/usr/local/lib/php’) in /home/atelier/public_html/demo/wp-content/themes/DEMO Finland/functions.php on line 9
The child theme apparently broke and default theme activated? I have now commented out line 9 so hoping this won’t cause issues?
Look forward to hearing from you,
Hash
The tagDiv Speed Booster works with our recommended plugins, with others plugins could cause incompatibility.
I recommend to deactivate it if you have other plugins active.
About the issue above, I’m not sure what you have there, but what you can do to be sure that everything is fine, is to make again the Theme + Child update and remove the tagDiv speed Booster if you don’t use it. Everything should work with no errors.
Hope this help!
