Hi again
After installing Newspaper at our site, I ran it through GTmetrix to check the site.
I’m a little surpriced to see that there’s two “high priority” problems regarding images, as I got the impression from your demo, that you were quite focused on handling images.
As you can see here, I’d like to solve the two trop problems – specifying image dimensions and serving scaled images instead of loading a huge image and the just resizing the look on screen:
Can you please talk a little about these two problems? 🙂
That issue is due to the responsive nature of the site. GTmetrix expects the theme to load a different set of images for each resolution. I think they test the site on a 1024px resolution and the site shrinks the images a bit. That is not doable because wordpress will have to generate a LOT of thumbnails for each resolution. Most of the themes (at least the wider ones) have this problem on GTmetrix.
Is like that because you don’t rebuild the thumbnails. Please follow this steps: http://import.tagdiv.com/newspaper/doc/#existing-content
