Site multi-author, advertising management
Before you go to your theme I was using one that showed a widget called “custom content author” where each author put their own ads.
Your site does not have, you can recommend some plugin can handle the ads for a multi-author site?
Thank you
Try this: https://wordpress.org/plugins/author-advertising-pro/, or try to find something similar. I have not tested it you could try any plugin you can find and see if it’s working I can’t recommend and guarantee one that works and helps you with that because we haven’t made any tests with this.
