I installed this theme yesterday with newseekpro template. The site is not loading on mobile devices properly. On ios, the site is responsive but the newsweek theme is not visible. On android, the site is not responsive at all. I have installed tagdiv mobile theme plugin and checked on the Mobile+Amp in the mobile settings section on themepanel Also, updating logo with tagdiv composer is really painful. Site’s url is timesofstartups.com
Trying to update header logo using tagdiv composer selecting viewport as phone but it is not updating the logo. What should i do?
AMP is deprecated as of January 2023-> https://developer.bigcommerce.com/docs/storefront/wordpress/platform-integration/enabling-amp so we don’t longer recommend it.
Also, if you want to use mobile theme then you need to set the logo in Theme panel -> mobile theme.
Please check this topic where I explained each mobile version -> https://forum.tagdiv.com/topic/mobile-version-not-working-properly-2/
