site showing the demo colours and fonts on page load
Hello everyone, I’m still customizing my website but every time I go to the URL, it shows for some seconds the default demo colors and fonts. Eventually it load the ones I have set but it is very annoying the change, how can I fix this please, I already tried cleanning the cache also but it is still happening.
Hello vivianaivi,
Please provide your website URL and then, provide more detail;s about your problems. Also, provide some useful screenshots with your issues for a better understanding.
I have the same problem!
I do have to change the style.css to avoid this.
I believe you are referring to the flash of the website on loading. That visibility of this flash depends on how well the website is optimized. If it takes a long time to load the effect is more visible.
The styles will load in cascade one after the other, until the last one. If you have custom code used to customize the website, enter it directly in the theme stylesheet. If you want to customize a demo, try doing it directly in the demo stylesheet
– https://www.screencast.com/t/wAoqG1Iy1
That way they will load with the rest of the style, removing or reducing this phenomenon.
