Hello, I see that you have a problem adjusting the top of the site.
Comments:
1 – The menu broke into one more line even though it had space on the sides. How to adjust this so that the CONTACT item is not down.
2 – The social network icons were above the thumbs. When you scroll the mouse it stays at the right top because a solid color appears behind it, but when entering the site typing the site address the icons are visible over the images. How to solve it?
3 – Where do I change the yellow color of the highlighted titles of the thumbs?
See attached image or link
Link – https://drive.google.com/file/d/1Cp55oP4iCkoGrZozCwlqDlA805sGt4KA/view?usp=sharing
Please check the width of the menu -> https://i.imgur.com/SsRkj75.png and check the value.
Also, you can change the color here open the css https://i.imgur.com/Rg6LPPa.jpg -> https://i.imgur.com/bBeL0qN.png
Thanks for the feedback Anna.
Doubts still arise. I need your help to move forward smoothly.
LOGO
I’ve added the tags and it doesn’t change at the top and bottom of the site. What do I need to do differently?
BUTTON COLOR BY CSS
The color I changed in the CSS, but the Hover color I didn’t identify by the CSS.
See the image the link – https://drive.google.com/file/d/1EIs1bDB1zmqb5I_TbZJ5VXxCJnIIoTym/view?usp=sharing
Delete the SVG code https://i.imgur.com/cFlE2tZ.pngAlso, if you add logo image or logo text make sure that are set to show ->
https://imgur.com/ve11Fwt
For the button here https://imgur.com/bBeL0qN
Hi Anna, thanks for the help. I managed to make the logo visible. You have been helping me a lot.
The more we stir, the more doubts arise.
What’s the best way to hide a block? Deleting it or hiding it? And when you do that do the tables reorganize?
I made an image for you to understand.
Link – https://drive.google.com/file/d/1ETj51m5pA6A5xWWg7Cz9JEGDrCzttcd8/view?usp=sharing
I recommend deleting the blocks. You can align the lement using the option on the row and column for layout or you can split the row into more columns. You can import the blocks from the cloud.
The menu can be centered like this -> https://i.imgur.com/irpRFlh.png Did you change the width on the column -> https://i.imgur.com/cKzBYab.jpg?
The icons are like that because the column is set to another width-> https://i.imgur.com/z1smkpW.jpg
Thanks Anna for the feedback.
The menu is misaligned due to the space occupied by the logo and the space to the right of it. It doesn’t change if I change the value in the WIDTH.
If I delete the magnifying glass in the home, does the magnifying glass disappear when my background loads when I scroll the mouse?
An item was missing to be answered in the image I sent you. Do you send it to me?
Ana, I have a problem that may interfere with the client’s approval.
Note that in my menu there are items that are the same as categories:
Category Cultural agenda
Category News
Category Interviews
Category Cultural sites
When hovering the mouse over each menu item, the items of each category must be loaded in the table below. How to do this?
IMAGE – https://drive.google.com/file/d/1E_z6GFU1K2vqvpwRJTABVvM9HyWbU4Gp/view?usp=sharing
You can then set another width https://imgur.com/GcyAdcr
Can you please provide a screenshot about this “If I delete the magnifying glass in the home, does the magnifying glass disappear when my background loads when I scroll the mouse?”?
Please provide a screenshot with the structure of your menu and the categories -> https://i.imgur.com/J18PatO.png -> https://i.imgur.com/6TbzYkG.png -> https://i.imgur.com/kRibeke.png
I went to change the color of the button in the CSS and when I saved everything the buttons went up. Now I went to the CSS and the space is empty.
Do you have that original code there for me to replace? I can’t tell you how the whole code was deleted.
Raw CSS empty – https://drive.google.com/file/d/1GS6_iBclq6nd1ub9-Ibf104pvECvAO6Z/view?usp=sharing
Good morning Ana, yesterday I presented it to the client and he liked it very much. Final stretch now.
I need your help to adjust some points. Can you see one by one?
I’ll list ok?
LINK – https://drive.google.com/file/d/1GsTCeDF_LH0yM9LSryFbsDQPdzIuyOO7/view?usp=sharing
1. The colors from Theme Panel, are general colors, you need to edit with tagdiv Composer, to change the style -> https://i.imgur.com/djPDZSH.png -> https://i.imgur.com/oKNcGyv.png
2. Usually, the ads are set in the element AD BOX, and you can remove it, edit with tagDiv Composer, select the Ad box element and with right-click you can delete it => https://www.screencast.com/t/2GfCVx9BCAw7 or with drag & drop place it into the deleting red zone from the bottom right of the page
3. You have set the global background color, if you delete the global background color then this color will apply-> https://www.screencast.com/t/7Os0qyqggHRR, please let me know what you want exactly to achieve.
4.You can use a different template for every category if you use a cloud template. You can duplicate a template, install a new one and assign it to the category you like, or create one from scratch by importing a blank template and building it as you like.
Check this topic: https://forum.tagdiv.com/topic/different-logo-in-categorypage/; Here is explained how to duplicate a header correctly and make some changes for a category template or other templates.
You can assign the template for each category in Theme Panel -> Categories.
Good morning Ana, how are you?
Today I’m going to create a user for my client to create the posts. What type of user do you recommend for her to edit and create posts without having access to the banners that are inside wordpress?
As I told you another time, I think it’s unnecessary for the client to have access to information about the topic. The customer does not understand how it works and thinks he is being wronged because we have purchased a solution through the NEWSLETTER Theme.
Question 1
What is the best user for the client to edit and create new posts without having access to the Theme’s info? I don’t want to expose the client to the template option and other features.
Question 2
I created a footer menu by wordpress and it doesn’t load the footer in the theme. How can I resolve this. If you need I share access to wordpress for you to help me.
The only link option that loads in the footer is from the main menu.
Question 3
In the site index I have 4 images with a black button with a caption inside. When hovering the mouse, the button turns blue with white letters. How to make these letters black?
Question 04
When will these banners leave the administrative part of WordPress?
Tagdiv places these banners without permission. It’s very invasive.
I tried in CSS and was unsuccessful.
Thank you, Ana.
1. You can change the roles and capabilities of your users from here: https://wordpress.org/support/article/roles-and-capabilities/
But, you can use a plugin for this, for example the Members – Membership & User Role Editor Plugin.
2. You can only modify the footer with TagDiv Composer if you go to a page where it is assigned and edit that page with TagDiv Composer, and then you will have access to the footer also. For example, edit your homepage with TagDiv Composer, scroll till footer, click on footer zone and you can edit it. For example, click on the row and change the background color: https://prnt.sc/d2Zti7GWIxPu
If you do not have footer, import a blank footer assign it on your homepage and make it global. Add the element List Menu and choose the menu already created in Appearance -> Menus from the element’s settings.
3. If you can edit the page with the TagDiv Composer, there you can edit the color and the hover color: https://prnt.sc/cAIY7Pd7MWYh
4. Do you mean these ads: https://prnt.sc/GhQA0Z126fmY ? You can disable it from here: https://prnt.sc/BDwqu0aItL2G
Hello, thanks for the feedback, but I think you read too fast and not understanding my questions.
Let’s go.
Question 01
Changing user roles we know. What I need to know from you is which one do you recommend to not have access to the Theme links. For example: as an EDITOR user, template functions are available in the list of lines on the left bar. This can not happen. Get it now? Which of the user options will the client not have access to the theme’s functions? What the customer needs is just to create posts and edit posts.
Question 2
I already created the elements for Footer, but they don’t load in footer.
https://drive.google.com/file/d/1S9_wgTviP4UE-8owEkgzms6mdLyZLtI4/view?usp=sharing
Question 3
I am referring to the IMAGE INFO BOX, it is this subtitle that I am referring to. I need to make this text white when the mouse has over the box.
https://drive.google.com/file/d/1S8gwB6m2xyUBGAGfYXZxsZJp5NAX9aSK/view?usp=sharing
Question 4
See how the theme is exposed when you create an EDITOR user. Look what she will have access to? View image
https://drive.google.com/file/d/1SAtPRBN1nEGMYR5Vlw0U7jzg4yw0xSsg/view?usp=sharing
1. If you want that your client to write posts, then set the role for author/contributor; you can find the capabilities for each role here -> https://wordpress.org/documentation/article/roles-and-capabilities/
2. You need to edit with tagDiv Composer, the footer template and you can use the list menu to add the menu -> https://i.imgur.com/x7BLJha.png -> https://i.imgur.com/TzSU5BI.png
3. Please edit with tagDiv Composer and check this -> https://i.imgur.com/MS3Oyzp.png
4. The editor and administrator have access to the cloud templates
Anna, are you okay? I hope you can help me.
The client loved the site and we decided to put it up. Everything perfect, but when we went to edit a post the system is not saving and it gives a JSON error. What can this be? On the internet it asks to uninstall the plugin builders. Do you need to do this yourself?
I’m not an advanced WordPress user and I really need the client to register new information on the site.
Can you help me.
If you need access to the site’s admin let me know and I’ll pass on the data. Would you pass by here?
I have a problem and I can’t solve it. It’s regarding the header and footer menu links.
Hovering the mouse over the links loads the related information for each link. Ok, It’s working perfectly, it loads the right information, but when clicking on the link in the header menu it loads a page with information that is not from the link.
What I need
Clicking on the menu link loads the page with the information related to the link.
Can you help me?
