Slide box problem
I tried to add several specific posts to the slide box, so tried to use post ID and the new category. However, both were not working. Previous categories are working on the slide box, but the new category and ID are not working on it. How can I fix it? I added a new license key on this site as it was copied from existing the other WordPress.
I just found that more than one post can show the slides, so at least two IDs and posts on the category show the slides.
  • This reply was modified 4 years by hanna2390.
