Slide component: problem with Post ID filter
I’ve set up my home page with different blocks and among those, i have used a slider component. Unfortunately, as soon as i insert a post id in order to show only one post, it just says: “no posts”.
Since when filtering for categories, it just works, i have created a new temp category and assigned that post to it, then filtered by this category. It always show “no posts”.
Is there some bug with this component or am i missing something?
Ok, i’ve just discovered that you need at least 2 posts to filter by, in order for the component to work. I mean, is this wanted or there’s a workaround?
Because you are using a slide element, you need to have at list to articles/posts sets in this way the post can be slide, if you want to display only a post, then is no need for a slider element.
