Slide from add element + issue `
Dear Team
I am trying to build a home page and use slide and when I choose it and update, the slide does not update and is not shown on the page I am trying to build.
is there an issue with slide?
sincerely
Harry
Hello harryst,
Please ensure you have followed the correct steps to add the slide and also, please make sure you have filtered this slide by existing category with posts in your site. An example -> http://screencast.com/t/QhsQrGEflZl
I’ve tested on my side and everything seems to work properly. Please ensure that you do not have plugins in conflict. After this advice, if your slide still does not work, please try to disable all the active plugins, except Visual Composer, clear all caches and install only the plugins that come bundled with our theme and try it again and rule out the conflict plugins.
Thank you for the message!
