Since the update I see options slide and it looks a legend: [vc_row] [vc_column width = "1/1"] [/ vc_column] [/ vc_row].
On the other hand are not well displayed, the blog is http://nksistemas.com
As you can fix this problem?
I also noticed that the images are very large, so try setting the slider on the page but not the option to edit more features slide, I need 2 things.
1 – How do I set sliders?
2 – That I have to do so that the images are VEAM as before, with the right size, the slide set?
