Every theme i’ve used, includes an update to the Slider Panel each time a Post is updated in WP Admin. The LATEST Post populates to the Front of the Slider Panel. Can someone alert me to where this feature is located in TagDiv Newspaper Theme? Thanks!
I’m not quite sure if I understand exactly the question.
I think you want to display the posts after modified data, if so, then this can be done using the tagDiv composer and setting filter on the block -> https://i.imgur.com/k7BO2Z8.png
If this is not what you mean, please let me know!
Thanks so much for the quick reply! I see the issue now. Somehow, i have the Composer plugin activated only for my pages, and not my posts? It appears at the top Menu of Word Process admin. for pages, no where to be found for my posts.
is there a button i missed in the setup of the theme?
Best regards
K
Hi besthomegear, to make it appears on pages you’ll need to use a single post template -> https://forum.tagdiv.com/single-post-shortcodes/ in this way you can edit the post template layout using the tagDiv Composer.
