Slider Problem
Dear All
I have a problem with the normal / small slider element. I use the correct picture formats as noted in your manual. But every time on any computer view I see some grey bottom layers at the bottom of every single slider.
PS: Do I check my website with an iPad, I have correct view and I cant see that grey layer.
Picture 1: http://www.screencast.com/t/LrdlwQVK0Z3t
Picture 2: http://www.screencast.com/t/LrdlwQVK0Z3t
Check it out: http://www.luxvisor.com
Best rgds
Roger
FYI: I have this problem only in the 980 pix version not in the 1170 pix version.
Bets rgds
Roger
Do you want to use the 980px version? If you want to use that version here is a fix for the slider, add this in style.css
.iosSlider-col-2, .iosSlider-col-2 .item {
    height: 321px !important;
Thank you, works well!
Best rgds
Roger
