Hi guys,
I have some problems with the slider:
-When I define a category filter, the slider disappear from the website
-When I try to define the height (by using extra class to the slider and change height css proprety) the title don’t show correctly and the slider looks weird on mobile device.
You can see it here: http://restaurant.qarth.net/
(I disabled the filter so you can see the both sliders)
Thanks,
If you define a category and the slider disappears, it probably means you have no posts to show in that category. The slider has to show posts. If there are no posts, nothing will be displayed. As for the height we do not recommend setting a fixed height to any element as it will break responsiveness. The height needs to be dynamic in a responsive environment.
Please contact us via email at contact@tagdiv.com and provide wp-admin so we can login and test this slider and see why it does not show up. Please provide a link to this topic as well so we can identify you.
