Slider Revolution cache problem with newspaper-politics
I´m developing a site using Newspaper and newspaper-politics, everything Is ok the first time, or when the browser cache is empty, but then don´t update by anyway.
https://politico.ar is the site.
I use W3 Total Cache, I tried deleting all caché and refreshing then de browser but don’t update.
I put W3 even to 60secs, and nothing.
I put on and off internal cache go RevSlider… but nothing.
If you enter now, and then you refresh a few time later you will see that the first slide is not the same as the later post in the first nodule.
If you use different browser then will be different slides that don’t change at all.
How can I force the browser to clean cache or how the browser detect that need to update when the site cache is cleared?
Im crazy with this
I can see that you use the Slide shortcode and not the Revolution Slide plugin.
Did you apply the same filter for the slide as the filter from the flex block?
Hello, I had to change because Revolution Slide don´t work properly. Is more beautiful, and have more options.. but don’t update in browser when new post is added. Literally I tried all that my knowledge let.
Slide shortcode is simple, with many limitations, but works.
I still need to use rev slider because is what the customer want.
Do you know id others have the same problem?
Unfortunately, we didn’t encounter any issues. However, I encourage you to use a slick slider, such as https://kenwheeler.github.io/slick/.
I hope that helps you!
