Slider Revolution does not work
Hi, I recently bought the Newspaper theme, but I’m having trouble activating Slider Revolution on my site.
I have already disabled the plugins, followed the tutorials displayed here in the forum, cleared the site cache, but it does not appear in the home of the site. How to proceed?
My site is https://www.tracionando.com.br/, but the theme is not active (I’m waiting for a solution for Slider Revolution to activate it).
Remembering that I’m doing this by importing the demo slider (Wedding)
Basically you need to install the Revolution slider plugin using this guide
– https://forum.tagdiv.com/how-to-install-revolution-slider-v5/
Then import a demo slider from the sliders provided in the theme package
– https://forum.tagdiv.com/import-revolution-sliders-on-demos/
And select the category from which the slider will display posts
Then place the slider in the page structure
– https://www.screencast.com/t/jkKVT0Odv
And choose the preferred installed slider if you have multiple sliders
– https://www.screencast.com/t/hJfUXxl7tI
If you have already tried these steps and the slider is not displaying, please check the theme status and make modifications to these parameters if necessary
