Slider revolution problem
Hello, now the problem is that the slider made is shown on the web for all users, but if I log in as admin or editor or another they are not shown, I add the screenshots. I have deactivated the plugin and it does not affect, I do not know if it is a problem with WP permission or the slider revolution itself, I need help please.
visible
logue on
page link
This is quite strange, usually it is vice versa, when you are logged you can see elements that are not display for unlogged users. Please check in incognito and with different browsers.
I can see in your screenshot that the space for that element is there but this is not display, it is possible to be something that is blocking it, can you check the console to see if you have some errors related to the revolution slider.
Let me know the results!
I do not see the reason or difference of the blocking of the slider in the theme, neither in the wp there is a choice for that, nor in the configuration of the revolution, in terms of permissions. I need guidance to know where to look, I have not installed any plugin, and I have checked removing them and nothing.
I have tried on mobile devices and with different browsers and nothing.
logue-> console
no logue-> console
page
I’ve tested your website and the images and the slider on homepage are not appearing, but after a refresh all are displaying fine.
Please try to clear your cache(also from your browser) and try again.
Hi there. The problem is the Revolution slider, which is only shown to unregistered users and is not shown to registered users, it is documented in the previous posts. That is the problem, when it enters the web if it loads everything that happens that I do not know because the first time the theme does not dump everything in the browser cache, only when it updates the second time.
Hi, this seems a strange situation, if you agree we’ll like to investigate it.
Please contact us at contact@tagdiv.com and provide wp-admin and cPanel credentials also make sure that you have a full backup for your website and database. Also please add the link of this topic in email to can identify you
I already sent mail. subject: Slider revolution problem
