I have problem with my website: http://leisurevn.com/ . It’s very slow to load my website. What is my problem? I wanna improve it.
I used this hosting service: https://uk.godaddy.com/hosting/web-hosting-config-new.aspx?src=ac&isc=gdbbt3404&plan=cpanel_tier2_036mo
Help me please,
Thank u.
Your site is currently dead. Its not loading to get it checked. For now, first thing to do is, if you have installed plugins, disable them all and see if that helps. If the speed is better, then try to re-active them one by one while checking the speed when activating each one. If its a plugin issue, you will notice the speed drops again as soon as you activate that particular plugin.
At this point, it is hard for anyone to check while your site is down. Maybe you need to check with your hosting company, specially if your site settings are correct.
Hope that helps
