Hello karakey,
This issue is known when using CDN or loading fonts from a different source. Please try to use this solution and take a look at this: http://screencast.com/t/AMjW530CSH6 and this: http://screencast.com/t/dLjEUGGwQUZ
The solution to this issue is simple. You will need to add some code to your .htaccess file like this post suggests: https://forum.tagdiv.com/topic/strange-chinese-symbols-replaced-icons-and-arrows/
Thank you for the message!
Hi Mr. Catalin
My problem is solved! Best Support! Thanks!
Details:
I added mini codes in .htaccess file look like this;
BEFORE
________________________________________
# BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\.php$ – [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php [L]
</IfModule>
# END WordPress
AFTER
<IfModule mod_headers.c>
Header add Access-Control-Allow-Origin “*”
# BEGIN WordPress
RewriteEngine On
RewriteBase /
</IfModule>
# END WordPress
