Small Images on Mobile
Hi, I’m using a pretty standard Newspaper Theme setup. For some reason these days, images on mobile look very small but they are fine on desktop. Any reason why that would happen?
.. I’m not using the Mobile Theme, BTW.
On version 9.2.2 and seeing the small images within Posts on a mobile device (Pixel 3XL).
Please replay only in your topic or in topics that have a similar problem with your problem, also notice that we take in order of time ( time when was post the question ) to answer the question, and if you post/replay again in your topic the time will change and will be move to recent question, therefore the answer will be delay.
Please provide me a link to your website where I can check this problem.
Is there a way I can message it to you? Thanks
OK, updated to 10.1 and seems to have fixed it now. I’m using ShortPixel to compress images and convert to WebP. Perhaps there was an issue with WebP in version 9?
Spoke too soon. Looked fine on Chrome Dev, but not on actual mobile devices. Ugh!
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
I’ve tried deactivating all plugins, same issue. Perhaps CSS? Seems like it could be related to the image size ratio (but guessing at this point).
I sent the information to that email address. Thanks for your help.
Thanks. Here is the custom CSS code I was given. Seems to work. Hopefully will be fixed in future updates.
.td-post-content img,
.td-post-content figure,
.td-post-content figure img{
width: 100%
Thank you for shearing the results on the forum!
If this is a general problem, this will be solved in the coming updates.
