Small multi column slider in 1 row
Hi, do you have a way to add a block section that offers more than one column over multiple columns?
See this link for example: http://allafrica.com/
It’s the slider directly below the banner ad which is below the menu.
Thank you
Hello Toriae,
Notice that our theme has a list which all available blocks which can be used for your website and which can be found here -> http://demo.tagdiv.com/newspaper/block-1/ There you will see how they will behave. You can try to use our IOS Slider, like this -> http://demo.tagdiv.com/newspaper/ios-slider/
If you want to display more levels in our theme and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, or also, you can try to use some plugins with this functionality and see how these will work for you.
Hi Catalin,
Thank you for your feedback, I have indeed had a look at the ios-slider, all we need is to allow more posts in one row, is there no CSS code you could give to increase the number of posts displayed on a single full column and still slide?
I.E. set the slider to show +/-6 posts out of all or 20 etc, and still slide?
Please there must be something you can do. We really appreciate your support and already spent most of the budget on the theme and counted on your support.
You can use the Big Grid Slider so you will display 4 articles and it still slides – http://demo.tagdiv.com/newspaper/big-grid-slide/
Unfortunately the theme doesn’t have a different element that you could use, sorry! Also please note that we offer technical support for the theme related issues based on envato support policy – https://themeforest.net/page/item_support_policy But we always try to help our user with some small modifications, so if there were another simple solution(css code) we have already provided it to you.
