Small problem when reading posts
I have some strange problem when i’m reading posts on my site Beograd.in. As you can see on screenshots below, there is some space on the right side that should not be there. Is there any way to fix this?
https://goo.gl/skvFVg
https://goo.gl/trXNFq
Best regards
I have inspected your site but I cannot see any issue.
Please provide more details.
This is happening only on mobile, please check with mobile and you will see that blue background on the right side when you scrool the page, it’s working normal on homepage, but on posts it looks very ugly when you accidentally move from right to left. Here is video: http://beograd.in/wp-content/uploads/2017/09/video-1505132889.mp4
Hope you can help with this.
Best regards
I see the issue now.
It is most likely a plugin causing this to happen. Please disable all plugins and test again. Clear cache after you disable them though. and disable the cache plugin last.
Let us know if you still have trouble without plugins.
