The event page shows two extra blocks, from the plugin company they said: Your theme is adding these extra <p> tags that is whats causing the extra bars please contact your theme.
In this photo you can see the problem: http://www.screencast.com/t/IEd6MzksR0p
I want to erase the two extra bars that are empty below each event, all this in the mobile version.
Hi Bogdan,
Sorry for not sending the link: http://www.ciclismochile.cl/calendario-de-carreras/
The problem is in the page for mobile.
Hellozunigafelipe,
I have checked your website and I did not saw any problem with your event section. ->https://www.screencast.com/t/uvNJBxb7G1p It seems to work as properly. So, please notice that plugin is not tested with our theme and we cannot provide support for untested plugins, sorry! If is not what you mean, provide more details so I will be able to provide a more accurate response.
Hi, I understand perfectly that if the plugin is not tested by you I can not ask for much.
The problem occurs only when I visit the page from a mobile phone. It is important since the majority of the visits are through mobiles.
I have the plugin with the mobile theme activated.
