Smart list 6 issue
Hi there!
Please suggest to me How can I decrease the size of the More stories Box which is displaying on the right side corner. Suggest me how to decrease it both Horizontal and also vertically. It will be helpful for me to avoid accidental clicks of my ads. I need your support.
Thank You! Please Reply Me.
1. The mobile theme can be enable or disable only on posts and pages, there is no option for category pages.
2. This can be done only with custom charges in theme files, since there is no option in theme to ad the ads in these plaice that you indicate (above I provide an example for how it can be don, but please note that this is not cover by support team to add custom code in theme).
You can set also the code in wp-content/plugins/td-composer/legacy/Newsmag/category.php -> https://i.imgur.com/YBfHKuC.png -> like this https://i.imgur.com/JTLp3Fl.png
also the More stories Box is displaying correctly if you have a monitor with a good resolution -> https://i.imgur.com/RqNgBnp.jpg if you want you can try this custom css
.td-more-articles-box {
width: 250px;
to reduce the More stories Box size. The code need to be set in theme panel> custom code> custom css.
Hope this will help you!
Have a nice weekend!
Hi sir,
1. On smart list 6 – [ https://prnt.sc/ufmp5j ]; How can I change this Numbering system 1, 2, 3 as Roman Letter I, II, III – [ Because sometimes the Numbering system is not adapt and suitable for the Titles, so I like to change].
2. Also, suggest to me how can I COmpletely Remove the Numbering system on smart list 6 and I like to have the Titles only.
Please suggest me solution for my Query 1 and 2 Please.
Thank You!
1. Unfortunately the theme do not have an option to can set the roman letters on smart list, sorry! As I know, for the moment this can be achieve only with custom work.
One solution is to set manually these roman letter in front of each smart header -> https://i.imgur.com/gaN7nIa.png
2. You can use a custom css to remove the numbering system from smart list -> https://i.imgur.com/5uBeEYN.png
.single .td-sml-current-item-nr {
display: none;
This code need to be set in theme panel > custom code> custom css.
results -> https://i.imgur.com/Qywd8uM.png
Hi Support Team,
1. I’m having Adsense based website. Actually I don’t know what is the exact width and stretch of my website. so please suggest me good looking width and stretch [ also better resolution] of my website in all the Devices like Desktop, PC, Laptop, and also in mobile. please tell me the exact settings and also I don’t know where to change this option in the Newsmag theme. so please let me know the steps to implement it. Please share screenshot
2. I’m using the Footer Template 1 in the Newsmag theme. by default, the social media Icons and contact us options are located on the left side of my Footer section. SO please suggest me how can I change it to the right side under the Popular category section. Please suggest me the solution.
3. when I created the Post the images I have placed in between the content [https://prnt.sc/uiaudd ], but after when I enable the smart list 6 option the images automatically came before the content. my query is when I enable SL 6 the images automatically move upward like this [ https://prnt.sc/uiawk9 ] and not the same as in the exact position while I created the post. so I like to have in between content after enabling the SL 6 option.
SO please suggest to me how can I keep the image as it is in the fixed position [between content] after enabling the smart list 6 option.
My Result should be like this after enabling smart list 6 —->
Thank You so much! Please Reply me.
  • This reply was modified 6 years by palani99.
Hi there!
1. Already you have provided me the Custom CSS code to remove Smartlist 6 Numbering system for all entire posts, so I’m requesting – please also provide me the codes to remove the numbering system on each and every individual post. It will be comfortable for me to remove the numbering on particular posts alone. Also, suggest to me for each and every post where I need to insert the codes which you are providing for this removal.
2. Actually on my Post the H2, H3 sizes are perfect [ https://prnt.sc/uibn40 ] but when after enabling the Smart list 6 the H2, H3, H4 sizes are changed [ https://prnt.sc/uibp84 ]. I like to have the exact H2, H3, and H4 sizes as like the Post after enabling the SL 6 option. Please give me the individuals codes for all these 3 headings H1, H2, and H3.
Thank You so much! Plz, Reply to me.
Also for Your Reference:- After enabling SL 6 – the H2 is like H3 [smaller ] and please check H3 which is like H2 [ larger] — [ https://prnt.sc/uicbc1 ]. I think the font changed entirely opposite in SL 6 – it is completely changed. SO please check out all my issues and please provide me a solution to have a perfect H2, H3, and H4 after enabling – smart list 6.
Thank You! Please Reply me.
Hi palani99,
What you are using a smart list then it will be apply a different style on it, to make sure that the h1, h2 .. will be the size you like, you can set the size in theme panel -> https://i.imgur.com/mTBuBWq.png for example for me h2 and h3 are looking like this -> https://i.imgur.com/oconpHL.png is look like this be default.
Also what numbers do you want still want to remove from your website, please provide me a link and some screenshots, in this way I will be able to provide a solution.
As for the footer, the theme has some pre-made footer templates with blocks that can not be edited, you can add only extra widgets in footer section, if you want to have control over the elements from footer, please use a footer like footer style 2, 3, 6 and add the blocks widgets you want to display. -> https://i.imgur.com/OvP5F6S.png -> https://i.imgur.com/JCvz78U.png -> https://forum.tagdiv.com/newsmag-footer-templates-2/
Hi Support Team,
1. H2 and H3 issues After enabling smart list 6:-
Sir, I have tested by changing the H2, and H3 size on the Theme fonts in the Theme panel – it only works for the Normal post, but not changing and not working on the smart list 6 option.
Actually on my Post the H2, H3 sizes are perfect in Normal post before enabling SL 6 [ https://prnt.sc/uibn40 ] but when After enabling the Smart list 6 the H2, H3, H4 sizes are changed [ https://prnt.sc/uibp84 ]. SO I like to have the exact H2, H3, and H4 sizes as like the Post after enabling the SL 6 option. Please give me the individuals codes for all these two headings H2 and H3. [ For Your Ref:- changing H2 & H3 on Theme panel option is not working for the Smart list 6]
2. I’m having Adsense based website. Actually I don’t know what is the exact width and stretch of my website. so please suggest me good looking width and stretch [ also better resolution] of my website in all the Devices like Desktop, PC, Laptop, and also in mobile. please tell me the exact settings and also I don’t know where to change this option in the Newsmag theme. so please let me know the steps to implement it. Share the screenshot.
3. IMAGES placement issues in Smart list 6:-
when I created the Post the IMAGES I have placed in between the content is perfect before enabling Smart list 6 [ https://prnt.sc/uiaudd ], but after when I enable the smart list 6 option the IMAGES automatically come before the content. my query is when I enable SL 6 the IMAGES automatically moves upward like this [ https://prnt.sc/uiawk9 ] and not the same as in the exact position while I created the post before SL 6. so I like to have IMAGES in-between content after enabling the SL 6 option.
Thank you so much! Please Reply me for my Query 1, 2 and 3.
1. Please try this custom css for h2 -> https://i.imgur.com/UzPF0es.png
.td_smart_list_6 h2 .td-sml-current-item-title {
font-size: 27px;
line-height: 38px;
letter-spacing: -0.02em;
Set the code in theme panel > custom code> custom css.
Also if you want to have the same size for all h you select for smart list, just remove the h2 from the code.
2. These are the most recommended size for ads per devices:
mobile : 300px X 250px
iPad : 336px X 280px
desktop: 728px X 90px
You can check more in this guide https://support.google.com/admanager/answer/1100453?hl=en
3. This is the way that the smart list was create -> https://i.imgur.com/T3XZ0mJ.png -> https://forum.tagdiv.com/newsmag-smart-lists/ the only way to achieve the smart list in the way you want is to make some change in theme files -> wp-content/plugins/td-composer/legacy/Newsmag/includes/smart_lists/td_smart_list_6.php
-> https://i.imgur.com/7gQYOfJ.png -> https://i.imgur.com/FYzq7Vp.png -> https://i.imgur.com/OQ70nY2.png
hope this will help you!
Hi Support Team,
1. You have Given me the AD size, but I have asked regarding the Website Display size [exact width and stretch of website] for all the devices like Laptop, Desktop, PC, Mobile, etc. I don’t know the exact Website size and resolution for all the Devices. SO please suggest me the exact size and also suggest me where I need to change these settings in the NEWSMAG Theme Panel.
2. I don’t know how to enable Website push Notification using our News mag theme. I’m a beginner and Please suggest to me how can I promote my Adsense Based Website by web push Notifications. Please let me how can I send the Notification of my post without Violating the Adsense Policy. It’s my Request please suggest.
Thank You so much! Please Reply Me.
1. I think that it will be better to use an adsense code that will check and will became responsive, here is the adsense documentation for this -> https://support.google.com/adsense/answer/9183460?hl=en&ref_topic=9183242 is not recommended to set a lots of ads for each view port in part.
2. Unfortunately we do not have a documentation for this, but if you are using Web Push Notifications they need to provide this kind of support. we can provide support only for the plugins you tested -> https://i.imgur.com/OEFiwPl.png
https://www.wpbeginner.com/wp-tutorials/how-to-add-web-push-notification-to-your-wordpress-site/
https://www.pushpro.io/en/push-notifications?gclid=EAIaIQobChMIsZ-6g_Py6wIVDAB7Ch0nSQfAEAAYAiAAEgLP6PD_BwE
Thank you for you understanding!
Hi Support Team,
1. Actually My question is – what are the Exact Website size settings for the Laptop, Mobile, Desktop, PC, etc.
I don’t know the exact length and width of my website for all devices. SO Please suggest me where to change the size of my website in my Newsmag theme Panel settings; Also Please let me know what are the exact size [length, breadth, and Height of my Blog should be for all devices]. please suggest me.
Thank you so much! Please Reply me.
Hi palani99,
Since the resolution for these device can differ (you can have two or more desktops, but these can have a different screen resolution, therefore the layout can differ if you are not using a box version), the only recommended size is to set the smallest size for each screens and above I just provide these size, the most use size for ads per devices.
Also for most of adsense ads you do not need to set an ad for each devices, because the adsense ads can adjust there size and these size require is more use for sidebars or other parts from the theme.
How can I change the text size on my mobile for the post and also the text comes under smart list 6 in mobile. Please suggest me.
There are options in theme panel> theme fonts> -> https://i.imgur.com/QDS4eTA.png but these elements will apply for all devices, not only for mobile, if you want only for mobile devices you need to use a custom css -> https://i.imgur.com/kAyisKx.png :
.single .td-post-content .td_smart_list_6 ul li, .single .td-post-content p {
font-size: 16px;
.post .td-post-next-prev-content a {
font-size: 16px;
This code need to be set in theme panel> custom code> advance css> phone
Hi sir,
Actually, my AD size 728*90 is not fit with my content box on the website [ extended from the left side and also on the right side it enters the sidebar]; herewith I have attached the screenshot for your ref:- https://prnt.sc/updhql
For your reference – I have temporarily disabled 728*90 and used Auto ad size on Desktop now. AT present you can see the auto ad size only on my website. The screenshot here i have shared https://prnt.sc/updhql is the proof of the tested ad size 728*90 on my website on theme panel settings. [ SO please don’t confuse with current ad display under the pagination of smart list 6 on my website now]
SO please suggest a solution that how can I fit this ad perfectly within the content-box on my website.
Hi, now I understand, the post content is only 679px -> https://i.imgur.com/nSM4eHv.png and when you are forcing to display and ad with 728×90 as in header then will get5 out of content because there is now enough space, therefore the 728×90 ads can be display only if you are using ca css code for resize, and this is not quite indicate, the best way it will be to use the responsive ads.
Viewing 19 posts - 26 through 44 (of 44 total)
