Smart List – Double image problem
Hello, I have already search for a solution in the forum and found that the solution for my problem is to quit strange signs from alt descrpition in the images I am using, I have already done but the problem continues, could you help me with some orientation? Here you could see the problem: Problema here
  • This topic was modified 10 years by jkarrlos.
There is another thing that creates this issue and that is the photon feature of jetpack. Please disable it as this option is known to cause issues with our theme and your smartlist should display properly again.
Thanks!!
