Smart list problem
I have a problem with the Smart List, as it turns out that option 1 “Smart List 1”, in the creation of entries is not shown in the full screen http://prntscr.com/mffozk, in the option “Smart list 2” , if the full screen works http://prntscr.com/mffq6i, but what I’m looking for is that it works as galleries in the option of Smart list 1, in the form of a slider
Ensure that you are using the latest version of the theme installed via FTP way, clear all the caches, purge CDN files and check the results. Notice that Smart list functionality is more sensible and if you are using some untested plugins, all of these might be affected. Remove all of the untested plugins, clear all the caches, purge CDN files and check the results.
