Smart list wont work for me, trying to modify next previous buttons
Hi I am trying really hard to get either the smart list working to have next buttons like
https://www.screencast.com/t/XWMryBUKie
or in general try to make them work such that there is a clean beautiful Previous and Next button.
I dont care for the numbers to work
Smart List 6 or 8 is good
For some reason now matter which I choose, there is no difference on my website after clearing cache.
I am also down to do this manually by modifying
‘nextpagelink’ => ‘<i class=”td-icon-menu-right”></i>’,
‘previouspagelink’ => ‘<i class=”td-icon-menu-left”></i>’
but havent got a resolution either
I have read previous posts but not sure why this issue is happening especially getting smart list to work
link to website
sparksports . io /special-moments-in-sports/17278/
So you would like to style the smart list buttons the same as in the image. If you could provide a link to the website where the buttons are located I will inspect them and try to give you a solution.
