Smart Lists, Categories and Other Questions
Hey all, I just need some help with two things I came across on my live site using the theme:
  • 1. For the Categories, I want Big Grid to show but for categories that doesn’t have sub-categories I see it lists out all the categories again (for example see here: Fashion Category which makes things a bit redundant. How do I remove that second listing from showing on category pages that doesn’t have a sub-category? (Here’s an example of a category with sub-categories: Hair Care with sub-categories
  • 2. For the Smart Lists (the one with the text then image), is there a way to get a footer text to show up underneath all the slides? For example, in this post: Smart List Example the ending text found in the last slide (#4 I think it is), I want that to be shown across ALL the slides/numbers. How do I accomplish that?
1. We designed this system to display all categories from the same level, on case of the main categories it will display them all.
There’s nothing wrong on your side, it’s just how this feature works. We’ll add some option or modify the code in one of the next update, this issue is on the list. For the moment you could hide those categories from Theme Panel – http://screencast.com/t/sxEk8t8zK but they won’t show up on post pages.
2. You have to add this tag at the end of your smartlist – http://screencast.com/t/osc6sfhbUa
Then add the content that will repeat on all slides.
Thank you, Emil G.
