Smart sidebar feature does not work
None of the smart sidebars work on my site. The td-ss-row class I added to those sidebars worked before. What should I do to fix it?
Hello BigHead_s,
Please ensure that you have fully followed all the steps from out tutorial here -> https://forum.tagdiv.com/smart-sidebar-2/ Also, please ensure that this type of issue does not come from your untested plugins which could interfere with the theme and also. could create some js errors which stopped this feature. Try to disable all the active plugins, leave just Visual Composer to active, clear all your caches, purge CDN file if you are using the CDN system and test it again and check the results.
