GO through this documentation : https://forum.tagdiv.com/smart-sidebar-2/
Sayeed.
You can set you sidebar for post from theme panel > template settings: http://screencast.com/t/7Clm0jfj8 also if you’re using a custom sidebar for a category page, it should be displayed also on the articles from that specific category.
Please provide more details and a link if this doesn’t help.
Don’t know if you are using visual composer to use the sidebar for your post, category or page, but the image and input the css class where in the row of the element for the widgetized sidebar. That made a non sticky sidebar stick. If you aren’t using the page builder, then sorry, just trying to help.
When editing the sites page for the sidebar in visual composer click the green edit pencil symbol for editing the widgetized sidebar. Select the sidebar for which one you want to use, if you haven’t.
If that is already done, then go to the widgets for that sidebar selected, and at either block 7 or 8 widget and add the category that you want, and that article has to be in that category. You can’t just put a specific article in the article by name it has to be done by category it is under. They don’t have any title options for just articles available, that I have seen.
Most of the settings are in the widget and are kind of long. So you have to play with the settings.
Click that + on the widgetized sidebar and it will open all the elements. You can probably find something that will add to there something to add a article with. I have not tried all of the elements for this theme. So good luck.
doucare1971.
