If you enable the smart sidebar from Theme Panel > Template Settings it should work also on posts: http://screencast.com/t/41ZEShs2gVr
Unfortunately you cannot make only one of the widgets from post’s sidebar to be sticky as the entire sidebar will be sticky there.
Instead on pages you can add this class td-ss-row to the row and will make it sticky – http://screencast.com/t/Nx6MqZW7FeAz
