Today I have updated my theme to 2.2, but shortly after that I realized that there is a problem with smart sidebars. The problem was that smart sidebars are going up more that they should. And first widget in sidebar was always hidden.
Then I have replaced tagdiv_theme.js with old js file from 2.1 and everything was working normal. Finally, I have found what is causing the problem and decided to share it with you, so you can fix it. If you want of course.
If you check row 5002 in tagdiv_theme.js, you will see this: td_affix_menu_computed_height = td_affix.main_menu_height + td_affix.menu_offset;
If you remove + td_affix.menu_offset and row 5002 become td_affix_menu_computed_height = td_affix.main_menu_height; then this problem is gone.
Regards.
