Hey there,
Sidebar is moving on the screen even though it shouldn’t ’cause width is not enough for it.
Take a look: https://pp.vk.me/c836222/v836222218/243ca/V_eG2ifd0ao.jpg
https://pp.vk.me/c836222/v836222218/243ac/I-Nfr0gjDDI.jpg
This is because some html structure in the post is creating an error. Maybe it is an open tag. Please test it on anew post without content. then if the issue does not happen on the new post, check your problematic post and try to figure out which part of the html causes the issue. Sidebars are sensitive to open html tags.
This could be a plugin conflict so please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
