Hey there,
Following the image and url of the website, the smart sidebar (right side of website) implemented seems to be (cut) off when scrolling. Two things just to clarify,
1. I did remove the top padding which was in the template (for alignment of the other website elements). But it seems to not be the cause of the smart sidebar spacing (Might be wrong).
.td-main-page-wrap {
padding-top: 0px; /*DESKTOP TOP PADDING. komenta: removed for space at top of page from 48px*/
/* responsive portrait phone */
2. I checked that with the removal of the 4 images at the bottom right doesn’t seem to cause the cropping of the smart sidebar too.
Website Url: https://leapdsc.com/leapdsc/client/astar/techdepot/overall-equipment-effectiveness-monitoring-system3-oeems3/
Image: https://1drv.ms/i/s!Ai3uwVtbSehutfx5EnHHta6Bo2W9Dg
Please suggest on how I should approach this.
Hope to hear from you soon!
Hello leapdsc,
I have inspected your website and I did not saw any problems with your sidebar, sorry! Where exactly is this issue? Provide more details and useful screenshots so I will be able to provide a more accurate response.
Hey there,
thank you for the quick response! As the image suggests, for all the smart sidebars applied in the website, the word seems to be cropped off (VENDORS DETAIL) when scrolling down the website. I am not sure if it is due to some changes I made to the website’s css. Please advice on how I can approach this.
Website Url: https://leapdsc.com/leapdsc/client/astar/techdepot/lorem-ipsum-dolor-sit-amet-consectetur-adipiscing-elit8-lidsacae8/
Hello leapdsc,
Unfortunately, I cannot find the problem regarding on your screenshot, sorry! I have inspected your website and I saw that your smart sidebar works as expected, as you can see here -> https://www.screencast.com/t/81kBTVW8y Where exactly is the problem?
