Hey all,
is there any custom css to make the menu on desktop NOT sticky while using the “Smart snap for mobile”-Option?
Thanks in advance
The the sticky menu it’s controlled by js and to make it visible only for desktop you need to add a condition in tagdiv_theme.js file like here: http://screencast.com/t/d2qjplNGPD Note that this modification will work only if you don’t use the Speed Booster plugin. In case you’re using this plugin the changes must be made in tagdiv_theme.min.js file.
Hello Andrei,
i think you didnt get me right. I want:
– Smart Snap on mobile
– WITHOUT having sticky menu on desktop
Thanks for your answer.
