guys please, can i this : https://www.biliste.com/bataryalarin-gelecegine-isik-tutan-5-madde/
<h3>number</h3> no more extra code
You can hide the title using custom css or editing the smart list file and remove the tile like this:
ex: for smart list title 3: http://screencast.com/t/P2Nt0HDTsV
and via css, like this: http://screencast.com/t/GyFNUGWqzW
.td-post-content .td-sml3-current-item-title {
display: none;
For the other matter you will need custom work as unfortunately the theme doesn’t have an option for it or you could also use the developers tools to edit the page copy the css used there and just it to work for you also.
Hope this helps!
Unfortunately the theme doesn’t have an option for this. The Smart List will use the title to generate the list. If you want only for some posts to hide the title you can use custom css for that smartlist post. This will hide the title only on that smartlist’s post: http://screencast.com/t/BMqvkythLtn
.postid-210 .td-sml2-current-item-title {
display: none;
Hope this helps!
